Need wire soldering help!
timdhawk
Argh! trying to do some work to my wirieng harness. Trying to replicate some of the factory splices of 3wires to one. I have tried both a 100w and 180w gun. I'm using solder paste and the solder that came with the guns. (one is from HF, the other from a local car parts store) It takes forever to heat the wires enough to flow the solder, which i have not made happen yet. I have resorted to using a little butane torch from my copper plumbing brazing kit. That works but obviously melt the wire covering.
What the hell am I doing wrong?????
you have to make sure you have rosin core solder, then (this is how i like to do it) heat the gun up, once its heated rest your wires on top of it all twisted together, then touch the solder to the tip of the gun so the solder runs into the wires.
you dont need the wires to be hot at all.... touch the solder to the gun, not to the wires. also buying good solder is much nicer then the stuff they supply with the gun.
When using an electric gun like that, I always touch the bottom of the wires with the gun and top with the solder.
I prefer a butane torch when on hand.
Woah there buddy. That's the best way to get a bad solder joint. The wires do indeed need to be hot enough to melt the solder so it "wets" down onto it. Otherwise the solder just sits on top and barely makes a bond.
If you can find it, get 60/40 rosin core solder if you don't have it already. It's got 40% lead which isn't supposed to be used anymore so I stocked up on it because I don't plan to chew on my motorcycle. The lead-free stuff can be touchy, it's got a higher melting point and the temp window is smaller.
If you can make a hook on each wire, hook them together, touch the iron to the wire and touch the solder to the wire. It has to flow around the wire. That is key letting it flow. Don`t forget to put your shrink tubing on first, then solder.
some great points here and i'll add some more. the key is to get the 60/40 rosin as already stated and another key point is make sure your solder iron tip is clean. take a piece of sand paper and make sure that tip super clean.. get a damn sponge and use it to clean the tip while soldering. once the tip is clean and at operating temp you want to tin the tip.melt some solder to the tip and wipe the excess on the sponge, then heat the wire and flow the solder into the wires to get a good bold. if the solder joint has a dull grey look it's a poor bond and the solder did not get hot enough.
Yeah, good tips everyone. Only one thing I'm curious about...what kind of instrument are you using? I've got an 80w soldering iron that I thought was bloody enormous, but 100 and 180??? You soldering half-inch conduit or what? I've never heard of irons with that kind of rating down here.
BTW, 60/38/2 (tin/lead/rosin) solder rocks! Hope it works out for you man.
Cheers - boingk
Actually, I use a 100/180 watt dual-range for my automotive wiring. My theory is that it jams a lot of heat into the joint quickly, so the heat doesn't have time to propagate down the wire and melt more insulation. I found the little 30W iron didn't have the snot to get the job done quick and get out.
Oh, another tip is to use a heat sink on either side of the joint. Something as simple as an alligator clip is fine. It keeps the heat from going down the wire and fouling the insulation up.
I can't tell you how many times I've forgotten the heat shrink...
Of course, we really shouldn't be soldering joints on our bikes. NASA and the FAA and a bunch of others have done studies, and properly crimped joints are more durable than soldered connections. Trouble is, I've never found those little 3-way splice crimps that the OP needs, just the ends like bullets and terminals.
Solder can be your worst enemy,factory connections are crimped to allow flexibilty between the wire and the connecter..if !! you apply too much solder,,,it goes below the connector, too the wire and makes the connection brittle...no theory applied here :o a very long push back to the truck and trailer,,,,,oh!!! cold solder joints, can be the devils revenge :-[
