Neutral light not coming on?
Odysseusdk
Hello everybody!
I just recently bought a very nice 73 CB 350.
But as always there will be minor niggles with bikes this age (Like I need to tell you guys ;) )
And my problem is that the neutral light never comes on?
How would I go about troubleshooting it?
Check the bulb first, then the wiring, then the sensor. I'd bet it's either the bulb or loose wiring.
Listen to Hillsy. Thats the way to go. Ill be honesty with ya though... You should never rely on the neutral light. Especially on an old Honda. They are not to be trusted. Learn to function without it and you'll be better off in the end.
ya, the neutral light on my cb350 only works intermittently, which is frustrating because neutral can be hard to find on this particular bike. oh well, i still make do.
When I first started messing with bikes, a friend whos been riding since the 60s stopped by to see what I was up to. At the time I was trying to wire up all the dummy lights. He asked why, and went on to tell me that on these old bikes, if you need little lights to tell you whats going on, you shouldnt be working on them. I thought he was just being a cranky old bastard, but over the years I realized that hes right. If you want to take an old bike apart and put it back together so that in the end its completely different, you shouldnt need a light to tell you anything. You should dedicate yourself to being completely aware of your bike at all times. Learn every noise, every trick, every weird nuance. Itll make you a better rider, and a better builder.
Von makes a good point about not relying on them. When I find neutral, and the light comes on, I still ease the clutch out to check rather than just letting go of the lever. I also rock the bike to check for neutral before kicking it over... just in case.
However, I'm CDO enough that... if it's there, it's gotta work ;)
(btw, CDO is just like OCD, except the letters are in alphabetical order... the way they should be ;) )
Whether you trust your neutral light or learn to live without it is one thing, but in most parts of the world it is a requirement to have a neutral light for the bike to pass inspection / be registered. So you will more than likely need to have it if you are planning on getting your project bike back on the road (unless you have a "friendly" inspector).
Most likely there is so much crud built up under the sprocket cover that it's stopping the wire from making a clean contact. If the bulb is ok and the wire looks good (check continuity) than the egg shaped thing that swivels can be cracked as well.
