New guy from Milwaukee.
DirtyFabrication
Hey everyone! I joined dotheton back in 2012 when I picked up my first vintage bike. I didn't do really anything on here since then. I have recently got the vintage bug again. I have a cb360 project bike and just recently acquired a CBX I will be starting on soon. Here's a few pics of my 360. Let me know what you guys think. I plan on being much more active on here for the future.
Looks like some nice work so far. Seems like you might be asking a lot of the swing arm though. Your shock mount looks beefy enough, but in its old 2 shock configuration, a lot of the load on the arm was sent directly up to the shocks. Now the two arms are just sticking out in space and it is much easier for them to deflect independently. Have you considered adding some bracing? Most monoshock designs either have triangulation bracing or the arms themselves are much larger with more rigid cross sections.
I also notice that you will have a declining mechanical rate as the suspension compresses which is generally not good as the suspension gets softer as its travel increases. Usually you want the softest most compliant spring and damping rate at normal ride height so small bumps can deflect the suspension, and want the rate to increase as the suspension deal with larger deflections so it does not bottom out on large bumps. In the simple non-linkage scheme you are using, usually you want the angle between the a line drawn from the swing arm pivot and the lower shock mount, and a line drawn through the length of the shock to come up to 90 degrees when the suspension is fully compressed. It looks like your set up has already moved past 90 degrees and will continue to reduce the rate as you reach full compression. You might want to re-consider the geometry you have.
Nice looking scoot man. I think JPmobius brings up some good points with the suspension design, but its a killer looking project =) im looking forward to seeing this thing come along!
Thanks for sharing it on the ton!
