NEW GUY! Looking for help
dachen
Hello everyone!
Just bought myself a 76' CB550 and need some help getting it to run again. This is my first bike so bare with me... The bike was running last night after I picked it up so I naturally toke it out for a test ride. I rode around for 6 miles and noticed the idle was jumping up so I parked and adjusted the idle screw a bit and then my bike died. I started it back up and as I pulled the clutch, the rpm's jumped again so I adjust the screw back down a little. Everything seemed back to normal so I started my ride back home. As I approached a red light the bike died again, but wouldn't start back up this time. I noticed the overflow lines (Not sure if thats the technical name) from the carbs started leaking gas when I was trying to start it and is still leaking slowly while the bike is off. Does anyone have any idea what might be going on?
Sounds like the floats are sticking in your carbs. The idle racing like that indicates that it was running lean(out of fuel).
Hey dachen,
Sounds like two separate problems there. The overflowing carbs don't have anything to do with the bike not starting again. Sounds more like a dead or low battery. That would explain why it would restart the first few times it stalled because when the bike stalls, the battery voltage will rise slightly, then when it restarts, the battery gets depleted again. Test the battery voltage with a meter. Should be somewhere over 12.5 volts or more with the ignition off. Your bike has an electromagnet in the alternator called a field coil. If this field coil doesn't have any battery power, the alternator won't make any power. If the alternator doesn't make power, then the bike runs off of the battery until the battery goes dead.
Charge the battery if it's low, then find out why the battery died. Test your charging system using the flowchart here:
https://www.electrosport.com/media/pdf/fault-finding-diagram.pdf
Good luck, and let us know how it goes!
It might be that one of the floats have a small hole causing fuel to get in. Also you might of fouled up the plugs.
