new guy old bike
obscene
Hi, all!
My name is Ben and I picked up this lovely gal last night. She's a 1981 XS650 Special II. This is my first bike and I'm pumped to learn and grow with it.
Please pardon my inexperience, but I have a couple of noob questions to get out of the way early:
1. What should I leave the fuel switch at when the bike is off? What is the prime for?
2. Do I need to alter the stock cables to use clubman bars?
3. Since it's an '81 Special II, am I out of luck for seats?
4. How many miles can I expect to get with a full tank?
THANK YOU!
*please feel free to include other useful xs650 information I may have overlooked.
** You can leave it on.. Its Vaccuum assisted and thustly wont flow untill the carb boot makes a suction**
** Your going to need to shorten the clutch and the brake lines, Gas not a problem. I reccomend a 28-30" Brake Line**
** the frame on the later XS's it weird. if you want to use a common flat seat pan you will have to modify the frame and remove the seat locks and move the rear brace.. Also you wont be able to run the stock rear fender with a flat seatpan. Or you can make a custome seat pan**
** On my 80XS 400 I get around 55-60 Miles per gallon and I believe its a 3 gallon tank**
If your cafe it here is what it can look like with some mods...
Just need to keep cleaning it up now......
Hope that helps.
Cheers
SETH - Rockers CT
Obscene,
Beautiful bike! I bought a 1980 XS650 Special new back in the day.... I wish I still had it.
I put drag bars on mine and didn't have to change the cables. Clubman's, probably shorter cables. This is a great engine, plenty of low end grunt and with the right pipes a teriffic sound!
Good luck with your new bike!
Scott
Thanks for the help and compliments, guys! I was a little worried I'd get the standard "search noob!" response.
Skyeye, did you wrists start to hurt with the drag bars? I like the way they stretch out the rider, but I'm not sure how the little amount of bend would feel after a while. As for the sound I totally agree. I'm guess with new pipes though I would need to get different jets for the carbs?
Obscene,
On my XS650 I had drag bars and a small fly-screen, it was a Yamaha option back then, very cool. I'm 6' 1" and the bike felt very good, no aching wrists, in fact I rode it to work everyday, 35 miles each way for three years.
If you go to different pipes and pod filters, yes, you will have to re-jet, but I don't have a recommendation.
Scott
Thanks, Scott. I think I'll give them a try.
Seth, I checked out your website. Nice club! Let me know when you guys are around Philly.
Will Do.. You should come up with the Maryland peeps to the Re-Union In Sept. Plenty of time to finish your XS
Cheers. Youll have fun building it
SETH
Crazypj,
That's a great site for 650 information, thanks. One thing I saw was a calling card template for members to print their own cards to drop off at businesses and to give to others with the same sickness!! We did this on the V-Rod forum too. Might be something for us here at Do the Ton.
Scott
