New Guy on the block
Restrick
Hey Everyone here at DTT!
i have been in love with cafes for well over 10 years, my brothers both own newer honda cb 600's one lives in Vancouver the other in new Brunswick. love them both but don't quite see eye to eye on motorcycles. I've always like owing machines, something with a real heart and soul.
My main objective was to buy a bike stock, strip it rebuild and have something i can call my own. But living in Toronto can make such a task difficult.
Now with countless nights searching, calling around, chasing bikes to have them purchased moments before i could even look at them. I felt discouraged,simply stopped looking. Until one day after about 3 months of just letting my dream fade to the back of my mind. i found this!
runs strong good throttle response, and compression. but won't idle. previous owner installed Mikunis, not sure what tuning/jetting was done to them before he installed them. Can anyone point me in the right direction. a good source for a shop manual or links to a similar issue .
now some of you might have noticed my post in the show and shine, rookie mistake still newish to this site.
i hope to pick the brains of any one willing to give me a chance to ask.
now lets all hope for an early spring!
Welcome onboard mate wow she is a stunner to start 8) looks like ya started where most of us want to finish haha ;D polishing and making bits is wot i do best but it sounds like ya carbs gotta be tweaked with the jetting ,pods n aftermarket exhaust tend to muck up the balance put a post up in the engine section headed engine will not idle sure ya get some answers ;) look forward to see ya posts mate good luck mate
Thank you!
Glad to be here! I made a post in the engine section,see if anyone can shed some light on it.
thanks for the tip!
Very nice bike, welcome. Sudco (other vendors also sell it) has the Mikuni carb manual, you should get a copy. Do a plug check right away, the plugs should have a coffee colour. If they are white or whitish then don't ride your bike until you richen it, running lean can ruin your engine. After you have made changes you need to put fresh plugs in to read the mixture colour. Make sure the PO put the correct size of carbs on your bike too. The idle mixture screw may fix your idling. Try turning them in 1/4 turn and see if this helps, if that does help then turn them another 1/4, if not try turning them out 1/4 turn. Make sure they are both adjusted the same. You may have to get different ones because there is a limit to how much you should adjust them. You should also check to make sure there are no leaks between the carbs and the cylinder heads, this can also lead to a dangerous lean condition. Did the P.O. report any problems? Good luck, just keep a record of what you do and work methodically and you will figure it out.
