New Sprocket Orientation
Finnigan
Over 1,000 Posts
Hey All,
Swapping out the stock cb360 (34 tooth) for a 38 tooth. Got her painted up and now I'm not sure which face should be towards the drive chain. The hardware isnt much of a clue since I'm going to have to modify either the nut or bolt (skirts?) to clear the lip. So, which way faces the chain: smooth or NOT smooth?
Thanks in advance guys and gals
hiya, just had a look here http://www.cmsnl.com/honda-cb360-usa_model1007/partslist/F++11.html#results and from what i can see it appears the NOT smooth side goes against the wheel, which kinda makes sense as there appears to be a sort of collar/raised area on the hub for the ring on the back of the sprocket to sit inside of
good luck spotty
The sprocket is from a 350 i think, looked up that model on the same website and it confirms exactly what you said.
Much appreciated!
