Needed a break from dents so decided to finally get the SOHC tank fitted and sitting how I want it on the DOHC frame. Started out with the original tank to get an idea of spacing and how much room there is to play with re the motor etc...
Also added the yokes and bars to make sure they do not hit the tank on full lock - this was a worry of mine as I thought they would, and id have to modify the rubber mounts to move the tank back a couple of cm however they do not and there is full clearance on both sides
Further modification required - the tank still needs to sit a few cm lower at the back and the tank bracket holder catches on frame in the corner, so they needed to be trimmed:
Once trimmed the tank sat lower which is good, but bade contact again from other parts underneath, therefore further heating and modification was required :S
After a few hours the tank is sitting at the required / wanted height and is making no contact with the frame
result ! However all the modification has appeared to dis-shaped the tank a bit - it is now wider that before. We simply compressed it a cm and its back and square again:
This is quite a step for me... from the start I wanted to use the older tank on the newer frame and now this step is almost complete. The tank is sitting how I want it :
I have learnt a lot getting to fit this tank, and know that next time I will do it differently
The better way would have been to simply cut away the problematic areas and weld them back with sheet metal etc rather than heating up the underside of the tank and modifying it with a hammer
however you live and learn and this is the whole point of this project !
