No Spark...No Fun
Brian8011
Well, I finally got the last pieces put back together on my '74 Honda CB350 and last night we tried to start it up and.....nothing. We tried kicking it for a good half hour and the thing wouldn't turn over. We did some tests and noticed that it wasn't sparking at all. The rest of the electronics seemed to work fine.
Anyone have any ideas?
Bad coils? Bad plug wires? Battery charged? Something disconnected? Something not connected right? Could be a few things.
Hook it up to a car battery (without it running) and try again. Refresh my memory, is the CB350 a parralell twin, or an opposed? You might have the plug wires reversed, so she wouldn't fire. Ground wires? lighting dim, non-existent?
Info is good ;)
I couldnt get a spark on mine, and all i had to do was sand the points till they were nice and shinny, and then everything works fine now.
350 is 4 cyl, right? open up the points cover and go through the timing steps in the manual, also, make sure the point contacts are clean. make sure your kill switch is not faulty. make sure your battery voltage is ok. why are you kicking it over anyway? that bike has a starter doesn't it? if the battery is too low for electric start, it's too low for a good spark. make sure your coils are properly grounded. other than that, keep messing about, you'll find it
