Herm21
So after resolving my starter issue (yeah 2 bad starters) I finally got the CB running. All has been fine until this weekend when she stopped starting. I trouble shot just about everything, points, timing, carbs, only to find that both spark plugs have gone bad??! How does that happen to new plugs?!? ???
These are two brand new plugs, they’re NGK B8ES which is what Honda recommends for the CB450 and they have less than 5 minutes burn time. They throw a spark when they’re a few cm’s away from the engine block, but refuse to spark when they’re touching the block. I had two older plugs sitting around, threw them in and she fired right up. I’m puzzled as to how these two new plugs went bad, do plugs short out, what causes that? ..on a side note which may be coincidence, I do have some electrical issues to still iron out, neutral indicator only flickers when the key is turned, the turn signals stay lit and don’t flash (I tried 2 other relays), and only the left one turns the indicator on. Could this coincidence be causing shorts in the plugs?
I obviously need to find the problem that caused the plugs to go bad to try and isolate it and keep it from happening again, any thoughts? -Herm
