Norton VR880 Commando
ca180
So I was looking at my usual search topics on on fleaBay and found this kick ass Norton. Just to clarify though, I do not own it, i do not know the person that owns it, nor am I promoting the sale of it. If it were mine there would be no way in HELL that I would be selling it!!!!!!!!!!!
Anyhow, to me it is one fine specimen of a classy cafe. I hope to own something this beautiful one day.... Of course at this moment in time I do not forsee that happening... Unless I hit the jackpot in the lottery!
I figured I would post some pictures here because after the auction is over they may be gone forever! Anyways, on to the pics!
That thing sparkles like a MAD WOMAN!!! How much was it going for? It's so nice and clean and shiny that it would almost be a shame to ride it!
Right now its $19,600 usd :o
Here's the specs from the auction
Vehicle Description
Less than 50 Norton VR880’s were built by Vintage Rebuilds in Gladstone OR., this is one of the last constructed. This stunning VR includes many changes from the first VR’s including Brembo brakes, Marzocchi front forks, alloy barrels, HD crankcase and Auto Meter gauges. The leather seat cover is snapped in place to facilitate changing seat height. This the only one I’ve seen with this feature.
Beautifully turned out in German silver with hand painted red and black striping, this VR has only covered 1700 miles since I originally purchased from Vintage Rebuilds. The sound from the hollow chamber pea-shooter mufflers and throttle response has to be experienced to be believed. It handles like it’s on rails and stops like a modern sports bike thanks to the contemporary Brembo brakes.
Unlike most older British bikes, this Norton doesn’t drip fluids but, it still “breathes” oil mist from some of its gasket joint areas. A light wipe down after each ride is all that is required. A small chip approx. 1/8” in diameter is on the front fender (it’s been touched up) is the only blemish on the paint. The bike comes with all documentation, original order sheet and extra belts for primary drive.
Below are changes and modifications since purchase:
§ Hand formed aluminum fuel tank by metal master Evan Wilcox
§ Custom Pingel fuel taps
§ Upgraded starter bracket with adjustment to set starter gear lash(double thickness)
§ New indexed starter gear
§ New aluminum coil brackets
§ Anti-sump valve
§ Oil tank recall
Vintage Rebuild build specifications are below:
ENGINE
§ Blueprinted, Dyno tested motor assembly
§ Dynamically balanced and lightened crank assembly
§ Oliver parabolic beam connecting rods
§ Newly cast left hand motor case 1” thick at the bearing wall
§ Koyo high capacity main bearings
§ JE 10.5 to 1 forged 79 mm pistons with low tension rings
§ Nikasil treated alloy cylinders
§ KVS negative crankcase ventilation system
§ Megacycle 6000 series camshaft .450 lift 277 degrees duration
§ Cylinder heads digitally ported and flowed by Baisley High Performance
§ Special 7mm stem valve set with radius valve adjusters for unrestricted flow
§ NASCAR type alloy high tensile push rods
§ 1.5” big bore header pipes
§ Polished cylinder head
§ Thermostatically controlled oil cooler
§ Spyke high torque electric starter motor
DRIVE TRAIN
§ RK Flat “O” ring chain 8000 lb. tensile strength /Super Cross technology
§ Sertco Cush Drive sprocket for no snatch smooth shifting drive train
§ QPD Belt primary drive system
§ Barnett Dry Flex clutch plates
§ Newly cast gearbox case with external reinforcement ribbing
§ New close ratio gears and shafts
§ Maintenance free anodized alloy rims with stainless spokes
§ Drilled and polished alloy primary drive cover
FRAME
§ Jet Black powder coated frame
§ Laser cut and drilled polished “Z” plates with knurled pegs
§ Integrated solo seat with custom upholstery
§ Machine cut stainless steel hardware
FUEL INDUCTION
§ Kehin 35 mm flat side smooth bore pumper carbs optimally jetted for the VR880
§ Racing type poly fuel cell with fiberglass shell (Replaced by Aluminum Tank)
§ K&N high volume air cleaner designed for the VR880
SUSPENSION
§ Reinforced frame for strength, stability and handling
§ Iso-max bottom motor mount
§ Marzocchi 38mm front forks
§ Progressive 418 adjustable shocks
§ Lightweight billet alloy machined hubs
§ Five position steering damper
§ Avon tires
ELECTRICAL
§ Power Arc Multi-Fire 80,000 volt ignition
§ Electronic regulator/rectifier
BRAKES
§ Brembo Floating type drilled brake rotors
§ Brembo Dual piston brake calipers with Ferodo racing compound pads (These are actually 4 pistons on front)
§ Abrasion proof Russel Performance vinyl covered stainless steel brake lines
§ Brembo master cylinder with 4 position adjust
CONTROLS
§ Motion Pro push pull cable system for safety
§ Magura competition type clutch lever
§ Adjustable bar-end mirrors
§ Autometer electronic speedometer and tachometer
I went to Vintage Rebuilds shop last time I was in Oregon... it's a bait shop now :( I asked the owner of the bait shop if they had left anything behind but all that was left was a Norton sticker on the wharehouse door.
