First, try tapping cover in slightly and check for a burr on the groove.
Get a longer 6mm bolt and screw it in until it bottoms out, you can use it to push the outer piece off (crank end is solid, not drilled for oil feed)
Try BikeBandit.com in the OEM section. fair price quick shipping. Or if you live in the GTA there is an awsome little shop called T.O cycle. They are off lakeshore rd just before you hit browns line. They actually stock alot of parts for older cb's I go there all the time.
