Open points
Bobby Joe
So this is more of a reality check...when the cam lobe lifts the points in the contact breaker, it causes the current from the primary circuit to break. Therefore, when the points are touching, there should be a spark in the corresponding cylinders. And then the points are not touching, there is no spark. Is this correct?
This applies to bikes with points, but since everyone asks...this is directly being applied to a 1971 CB500F K0
When the points open, it breaks the current which collapses the magnetic field in the coils with the spark being the end result. So, basically you have it backwards.
That's actually backwards. You gotta remember that there are two windings in your coil; primary and secondary. The primary winding is the one that's grounded through the points. When the points are closed, current is allowed to flow through the primary winding on its way to ground, which is what electricity loves to do. All the while it's building up an electromagnetic field (EMF) because of the many times it's wound around in the coil. When the points are open, the EMF needs to find a new ground so the energy gets transferred to the secondary winding and though the spark plug gap to ground, creating a spark. So the spark occurs when the points are open.
I am posting this just before I head to read the write up...
If the points never close, but instead go from the suggested gap to a much larger gap...(fill in the rest).
Ok, so when the points are closed, a charge is induced. But if they are never touching, then the capacitor will never charge. 1. there will be no spark. 2. There will be no draw on the battery either. Correct?
Why?
Read it and understand how it works before asking stupid questions.
We are all more than happy to help you understand how your ignition system works, but I for one cannot abide by laziness. Read the write up I pointed you to first.
