Opening up a DCC Tach
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
Hey guys!
I bought a small face DCC tach some months ago and need to match its kilometres to my stock tacho that I removed (its important for MOT).
I tried to connect the tach to a drill press but it would take ages to make the right kilometres.
So now i thought about opening it up and turning the numbers by hand.
Before I try this,has anyone of you evee done this before?
Will it be possible to turn the numbers over by hand or are they somehow locked?
How do I remove the plug on the side for the day kilometres?
I guess I need to bend that lip on the edge of the tach up in order to remove the face from the rest of the tach...
The gearing inside is specifically designed for you NOT to be able to do that.
Usually there is an exemption form or something you can fill out in case the odometer needs to be replaced.
