opinion on gauges
Rimmy
Hey guys,
I was updating the gauges from by CB350 recently. I polished the housing and put on some new white faces I got off of eBay. They used to be black/green now they're shiny/white!
Anyhow, I need to paint the end of the needle red, so I can see the contrast easily enough, but I'm just curious if I should paint the rest of the needle some color. Of the bikes I've ridden I've never really payed attention to the color combo of the needle/face but white on white doesn't seem like it will be very noticeable. Any suggestions?
-jordan
I painted the whole needle. Used Testor's model paint and a small artist's brush. I like it.
CC
I f$%cking love the way those look with the white faces and polished housings! I too would paint only the tips red or the whole needle red, but not two different colors.
So those gauge faces eliminate the original holes for instrument lights? I like that idea because I was also thinking about putting all my indicator lights and ignition switch on the triple clamp.
Would you care to share a link to the ebay seller's store? Can't find gauge faces for some reason.
Thanks!
I'd go with just the tips done and leave the remainder of the needle white. That way you'll be able to see if you hit redline. :) If they are all red, it'll blend into the red section and make it hard to see when glancing at it at speed. It'll make it easier to see across the entire rpm range.
Thanks for the replies, input and compliments! I've decided to go with red tips (I'll post pics after I get it done).
For those of you interested, the eBay seller is catiawheels. http://myworld.ebay.com/catiawheels?ssPageName=ADME:X:RTQ:US:1181 The seller doesn't have the CB350 listed, but I emailed him and he said they'd work. It took a little cutting with an X-acto knife but the product came out pretty good. One note of caution though, when you look real close, you can see slight pixelation on the numbers and dashes. You really have to look closely to notice it though. Like, really closely. Unless you're an absolute perfectionist I wouldn't let that deter you.
-jordan
I'd go red all day long. CC's look great, and the "disappearing red-line needle" thing is a bit of a red herring. You'll know when you hit red-line. It doesn't just happen, it winds up to it.
Your gauges look great, but a white needle with just a red tip doesn't look right. If you've got them open, paint it all red. You won't regret it.
cheers
ian
