Painting Another Helmet (Finished Video)
johnu
Over 1,000 Posts
DTT BOTM WINNER
Just started another helmet. A little more intricate this time.
Well I finished the second helmet and it was a nightmare! Originally this helmet had lots of graphics on it and I don't think I sanded some of them off well enough so when I pulled off some off my mask it pulled off some of my paint and the original paint:mad: It meant I had to sand down some areas and repaint them. It turned out ok in the end but I will be starting with new basic white helmets from now on. The color in the video is off, the orange is way brighter, almost like a pearlized KTM orange. Also I have not buffed the clear coat yet.
Spraymax is great. Wonder how long before regulators find a way to force a formula change so it isn't as good?
So I have just boughtva Shoie GTvAir ll.
Its a matt finish and I want it gloss Is 2pk clear an option then.
Sent from my SM-N986B using Tapatalk
Depending on how matt it is. Water borne is pretty matt when spayed, but the Spraymax Glamor Clear made it really nice and shiny. If it is mat so much that it has a texture, you should wet sand it flat first.
My helmets are not totally matt before I clear them I would say more of a satin to semi gloss so not sure if spraying over matt would come out full gloss but, I would expect it to. When I use the spraymax 2k glamor I usually lay down a light first coat then let it get just beyond tacky and do a full on heavy coat followed by two more heavy coats again leaving it to get tacky between coats. You should be able to do this with one can. I find you can apply it heavier than you would think but there is a fine line of course as you don't want any sagging.
