Painting over chrome.
Staffy
It's not yours 'til you cut it up.
Looking for a rundown on the best ways to paint over chrome and have it last. There are times where you can take the chrome off and others you can't. I dunno, a "painting chrome parts for dummies" step by step guide is what i'm after.
If you have access to a media blaster, that is the best way, but other than that you need to scuff it to give the paint some bite. 400 grit is a good place to start. The reason paint sucks so bad on chrome is because it is so slick. Paint needs something to "bite" into, and that helps. rough it up and then hit it with anadhesion promoter like "Bulldog" for plastics. sounds crazy, but it works.
But if oyu can talk somebody into blasting the parts you'll have no problem at all.
If you have a chrome shop locally have them throw it in the tank with the charge reversed, chrome will come off completely. You can media blast it but i haven't seen great long term results.
If you're on a tight budget, scuffing it and adhesion promoter is the way to go. If the part's not exposed to high heat, the two paints I've had the best luck with are spray on bedliner or appliance epoxy paint.
I scuffed mine up by hand and with a palm sander using 80 grit.
took me probably an hour of sanding my rims to be satisfied.
It's holding well....passes the fingernail test.
And if it is exposed to heat, say exhaust chrome for example? Does that require a full de-chroming?
nah... just a high temp paint. Krylon barbq paint works, but it's not very durable. Anything capable of handling 1200 degrees should be more than sufficient.
Got some of that already. That'll go on once the bike's up and running again. Cheers deviant
