Painting Question - Flat Black
HerrDeacon
Over 1,000 Posts
I'm about to start painting my front fender but I have a couple of questions. I'm painting it flat black and I'm wondering if the process is the same for painting a flat paint as it is for a gloss paint? I've painted gloss before and what I do is lay the paint, wet sand and then buff and polish to remove the fine sanding marks and bring up the shine. I'm wondering if this same process applies to flat paint? I'm mainly concerned with the buffing part and removing the sanding marks from the wet sand. I'm starting with the front fender so I can perfect it before moving on to the tank and seat hump.
I've searched but couldn't really find much help. Anyone have any good painting forums bookmarked?
Any help or links would be appreciated.
Assuming your fender is chrome you can choose to scuff the surface with a sander to get better paint adhesion or leave it in case you ever decide to strip it and go back to chrome. Either way clean it with lacquer thinner, then spray a couple of coats with automotive primer. If it gets uneven, wet sand. Once the primer is nice and smooth spray a couple of coats of flat. Apply more coats if necessary to get an even coat. Don't buff it, that will defeat the purpose of matte black paint. Buffing is for attaining a high gloss finish. Let dry for a couple of days before installing.
No, it's not chrome, it's just a plain metal fender that was previously painted red. I have it prepped and ready to be painted. I'm really just concerned with removing the final sanding marks. I'm not a professional and I know my final coat of paint will not be totally smooth and/or free of dust, etc, so I was planning on wet sanding it, finishing with a 2000 grit. This is what I do when painting with gloss, but I just use a dual action polisher/cleaner to remove the 2000 sanding marks. Thinking that this will ruin the flat finish though. Guess I'll have to try it out and experiment a bit. Thanks.
if you're speaking of the sanding marks prior to painting, a high build primer will take care of that. Other than that, 2000 grit will leave marks that you will never see, so long as you final sand in one direction. Another thing to try that i have recently found that works fantastic, glazing putty. Use in VERY light passes, and sand down to 2000 grit, wet, smooth as a baby's booty.
No, the sanding marks I'm speaking of are after the final coat of paint has been applied and wetsanded with 2000 grit. I know when painting with gloss paint that these marks were still visible and I had to buff them out to get the best possible result. With that said, with gloss the sanding marks are really visible because of the light reflection so that all the swirl and sanding marks show up really good. This may not be a problem with the flat finish where there is no real reflection like gloss. I guess I'll have to see after I have a few coats of paint on, may not be an issue at all. I just want to try and get the smoothest finish that I can do. I'll post some pics if I do a decent job.
I know on my tank, i went the full gammit of paper grits, and in the end i had NO swirl marks at all. From 400 to 2000 all wet, then cleared and sanded numerous times. Didnt have any swirl marks. Will be interested to see what happens, but i have the feeling like you, with flat black you wont see much in the way of defects.
I hope I don't see too much. Not a big concern on the fender, but would like the tank and seat hump to be presentable. If I can't get it to look the way I want I'll just switch to gloss black, but I hope I don't have to.
I don't think you'll have to worry too much about your imperfections showing up in the flat finish. the 2000 on my primer gave it a perfect finish.
Put one drop of DAWN in a bucket of water and soak your 2000 grit, then keep the same mixture in a squirt bottle to keep it damp. Has to be dawn, though, other detergents can harm the paint.
I'd suggest using some kinda matte clearcoat as well... though I've never used it myself.
I painted my car flat black and you basically get 1 shot to get it right. I messed up and and tried wet-sanding a spot and had to re-do it. What happens is, it gets a polish to it. To get the flat effect, I used a PPG Flex-n-Flat clearcoat (which is already flat) and added additional flattening agent to it. I shot this over a gloss black.
I didn't try to use primer, nor sand on it.
--Chris
I wasn't even aware that you could get a flat clear. I used a satin before but not flat. I painted the front fender yesterday and it turned out pretty good. I don't even need to wet sand, I'm pleased with it. I'll start prepping the tank this week and give that a go, hopefully it'll turn out as good as the fender.
