TonUpSoldier
bad assed, super fast and fully gassed
I had originally thought to try and fix her back up, but i got an offer on the frame from a fellow GSr in need...so i couldnt turn it down...Aside from body parts, (tank seat side covers..) i have it..airbox carbs (tho someone has expressed intrest in those too) The top end is questionable...i havent pulled it apart to inspect other than i know the cams are a little scored. Electricals are all there...gauge package, harness, rear light, i have a pair of signals, you name it i probably have it..I'd like to only sell these parts to guys or gals on here who are in need, and at reasonable prices..im not looking to make a fortune on these parts, just some extra cash toward my Cafe project, and to help fix up a couple other bikes i have to get them unloaded...if you're looking for something..PM me..all offers will be considered..
SOLD:
Frame (not the swingarm however, just the nekid frame)
Gauges
Carbs
Lefthand switch
AVAILABLE: All this stuff is in good shape guys!
stock airbox
forks
swingarm
front and rear rims
wiring harness (completely unmolested)
decent looking set of superbike bars
Motor parts minus the stator and cover.edit-stator and cover are both still available -edit
Starter
Stock tail light
pegs
sprockets (in decent useable shape)
headlight ears/brackets
Throttle sleeve
Right hand switch
4into2 Stock Exhaust (this has a patch on one of the pipes, not visable when mounted and should be good to go for a couple more years at least. they need a bit of cleaning up..i may do that if i get around to it)
Two Front Calipers
Two front Discs
One Rear Disc
Chain guard in good shape...may want to paint it...may not...
Clutch basket with good looking fibres and plates, i also have the springs tho i have not measured them they came off the bike and according to PO were in perfect working order.
And various other odds and ends that you may need for your rebuild...
Again not looking to retire off the sale of this stuff, any reasonable offer accepted..I need more room and the extra little bit of cash to help on my GS cafe project...I WONT ebay this stuff for some shnook to f-up..id rather see it go to guys who love these bikes...
ALSO I still have a set of gauges from i dunno what model GS.. its the big one with the speedo, tach, oil temp, fuel, side stand light, gear pos indicator..all wiring is intact and untouched...Its way too big and gaudy for my bike so its gotta go too....
Also i have a working speedo from a GS450...still has the sticker reminding you to change your oil or whatever it says...looks good
SOLD:
Gauges
Carbs
Lefthand switch
stock airbox
forks
swingarm
front and rear rims
Starter
Stock tail light
pegs
Throttle sleeve
Right hand switch
Two Front Calipers
Two front Discs
One Rear Disc
