pressure washing an engine?
sbaugz
DTT BOTM winner
So I am restoring a T500 suzuki- actually doing a cafe build.
Jugs were removed- going to be vapor blasted. Side covers all removed- going to be powder coated. I have been slowly picking away at the crankcase, which is literally coated in an inch of oil, sludge, mud, and petrified hornets nests. I got it pretty darn clean, but I can't seem to get all the tiny nooks and crannies. Before I send away the jugs and side covers, I was thinking about bolting those back on (without gaskets), putting plugs back in the heads, covering the exhaust and carb inlet holes, and pressure washing the crap out of the crankcase. I just wonder if this is a good idea or not? I worry about causing a leak in the various seals (kickstarter, clutch detent, gear shifter, oil pump, etc, etc.). I also worry about water getting inside the crankcase. Has anyone done this? would you recommend it? I suppose after I get done blasting it, I could remove the jugs, turn upside down and make sure all the water is out and then fill it right back up with oil.
opinions requested.
Thanks.
i dont understand what you are doing . . if the cases are empty you can water blast then but it will all come cleaner if you media blast them then clear coat them with clear lacquer.
if the cases have the gears and crank, i wouldnt do that.
Not sure why there is confusion. I thought it was clear.
Everything is in crankcase and crankcase is not split. . I'm saying that I want to take my pressure washer and wash the engine after I put the jugs and side covers back on.
---not a vapor blaster, just my Honda pressure washer that I use to wash my deck.
The engine gets wet in the rain, so I'm wondering why I can't pressure wash a complete, assembled engine if I close off intake and exhaust holes?
barnett468 said:
you can pressure wash it all day long if you have the gaskets in it.
Sorry to contradict Mr. Barnett (much good advice generously offered sir - my compliments) but it is absolutely possible and I think very likely that most pressure washers are well able to force water in where where it does not belong. I would agree that in the main, a completely assembled engine in running condition should withstand pressure washing, but even then it is a bad idea. I suppose if you button it all back up - gaskets and all on the top end, and you are reasonably careful not to aim the spray jet at any of the joints, you may be ok. I have seen numerous examples of terrible damage that was the result of pressure washer water forced past seals into wheel bearings, swing arm pivots and electrical plugs and looms, etc, etc that would never had an issue otherwise. Can't say I can attest to engine damage, but by the time you see some problem there you might not ever attribute it to that cause. Probably better of using patience, determination and conventional methods to pick everything clean.
pressure washing wont remove stains either . . another option is to clean it with a garden hose and citrus cleaner and a plastic toothebrush . . wd40 cleans grease well also.
as far as pressure washing motorcycle engines goes, i have done it over 200 times so my comments are based on over 200 experiences, bit if you have weak gaskets etc, some water might get past them, but it definitely can get in electrical joints and wheels as described if you blast them.
