Problems when warmed up.
Smoking Star
Left side smokes when bike warms up. and after its warmed up the clutch slipps and it gear changing isnt as smooth, and it developed some poping at idle. im going to try a heavier weighted oil and see if it helps.. Other then that it kicks over on even the lightest kick start.
oil didnt help much, I cleared up the popping, but the clutch/ gear change still exists. could i not be getting any oil pressure?
Replace the clutch cable and adjust as per your manual. Switch your oil to Shell Rotella 10w40w, sometimes modern oils has additives that can really cause the the clutch to slip. If none of the above work, I'd be pulling the clutch cover to check if new plates are in order.
Terry
J'ville, Fl
