Problems with original harness.... go custom?
aroe
Hi guys
Problems problems problems with factory harness on my 360. I don't consider myself that electrically retarded, but there are things going on that just done make sense to me... additionally, I have continuity between battery positive and any ground.. cannot figure out where it's happening!
What's the best option here? Tear down the existing harness and put it together bit by bit? Buy a complete harness? Or buy a rolle of wiring and bullet connectors and get to business?
Cheers
Get a wiring diagram and work out what is happening with your current harness.
If you are having trouble working that out, then trying to make a new harness from scratch is probably not a good idea.
Building a new harness is often a lot less work than trouble shooting an old one.
If you do want to start trouble-shooting, start my measuring continuity between the positive terminal and ground. Continue taking readings while disconnecting one thing at a time. At some point you'll either find your trouble spot or rule out all of the components (making the issue one of the wires). Most likely issue is going to be a red or red/white wire touching bare metal and grounding out.
Matt's (Sonreir) too polite to also mention he makes custom wiring harnesses and has all the bits and pieces you need to plug into them.
http://www.sparckmoto.com
