Rocketeer85
Goin to be a bear, might as well be a grizzly..
So I got the universal rearsets and linkage kit from dimecity. They fir perfect and the linkage kits are the perfect size. Only problem...(forgive my ignorance.) Where to the linkage kits connect to? When I look at other pics there is a small piece that connects to the actual shift bar that will link the linkage bars. It looks like a small triangle. I emailed the dimecity guys and there responce was " use a nut and bolt" not much help there. Do most guys make a piece? And also the linkage kit has a movable bearing inside Im assuming its not a nut considering it would restrict bearing movement. Any Ideas?
Its that small piece to the top left connected to the line.
