kopcicle
antidisestablishmentarian
[rant]
Of the 1000 or so regular customers I dealt with over the last 30 years only 5 could so completely clean a set of carburettors that they worked . I'm willing to bet you are not one of them . I don't care how completely you think you cleaned them , you didn't .
All jets have to be visually inspected as well as their passages . Find a diagram of fuel flow in that carb and verify that the passages are clear and I mean clear , without residue of any kind . I use the straw and can of something to verify as well as air pressure . Only then can you fine tune the carbs . Sync , idle speed ,idle mixture , wash rinse repeat until it's right or you get sick of getting no closer .
Once you are sure of the carbs move to the valve adjust. That is well covered here , elsewhere and in the factory manual . You must get this right . I'm more anal about valve adjust than some but it has paid off in the long run . Look for suck squeeze bang blow around here and on the web . I go into boring depth about valve adjust there .
The points adjustment is another thing I blathered on about in some detail . You must get the dwell nearly identical as well as establish full advance timing identically for both sets of points . The static , initial or full retard settings are not as critical but have to be reasonably the same . One thing that can contribute to strange performance issues is a stuck , warped , weird , corroded , loose , worn out spring , or generally foobar advance mechanism . Verify by hand and by timing light that it works correctly .
There is no magic , no short cut , no guess work , magic bullet , savior from above or below that it going to make things right . It's all about you , your attention to detail , your ability to follow directions , your dedication to craft and lastly your innate mechanical ability .
I'll summarize
adjust the valves
you didn't clean the carbs , try again
adjust the valves
verify the advance mechanism works correctly
get the timing as near perfect as possible
adjust the valves
only then can you ...
sync and adjust the carbs and have it mean anything
did I mention adjust the valves ?
I had all this beat into me (literally and figuratively) at an early age and is much like breathing to me but is a mystical cypher to others . I get that but it is what it is and has to be done in the order , valve , electrical , carb or you are lost . [/rant]
~kop
I'll summarize
adjust the valves
adjust the valves
adjust the valves
~kop
