RD Primary Nut Question
2_DONE_THE_TON
Over 1,000 Posts
DTT BOTM WINNER
do you guys put loctite blue on the primary thread?since there is no safety washer that could lock the nut it prob would be ok.
the manual says nothing.
Are you talking about the primary gear nut on the end of the crank?
There is supposed to be a " BELLEVILLE" type spring lock washer under the nut. It is part number 214-16119-00-00
Maybe yours is missing, you have a regular flat washer from someone's mistake in there or: you do have the correct washer and are ok.
The Belleville style is not a split style lock washer, it is spring steel and does not lay flat. When on a flat surface one side will mushroom up in the middle, that is the side that faces the nut. When you tighten the nut, the washer flattens and maintains pressure on the threads to keep the nut secured. They are quite awesome.
If it is missing, I have one here
thank you.there is a "washer" underneath the nut....dunno if its this kinda type.
that looks like what he speaks of but if you have some loctite it will do no harm
and for god's sakes do not use a screwdriver between the gear teeth :o
Bump it with a impact wrench once or twice then drink a beer and call it a day
is it ok to drink two beers too afterwards? :-)
and how do you guys block the crank...the manual says using the chain on the sprocket...i mean if i put my impact gun to use without blocking it it will spin like crazy..
what about the copper dime idea?i mean it CANNOT harm the steel teeth of the primary and clutch...
my machinist told me to stick a piece of aluminium in the crank slot...worked great at the disassembly.crank is true.no harm to the crank.
