RD250
2stroker
1974 Rd 250
Hey DDT,
i have been reading up on these forums for the past month and it was about time for me to register. I have a very stock 1974 Rd 250. I bought it with 2,400 miles on it and just a minor scratch on the tank. Im keeping my bike stock for the most part but i am also doing some fun things to it to. Currnetly im making a foam mold for a seat. i have watched countless videos and read may internet walk throughs. so far its a fun project. I like it alot. I am looking for parts as well. such as forks and a front tire off of an 350. I reall need disc breaks to help me slow down. Also im trying to find front and rear fenders because i really do want to cut mine up being that they are original. i will post pictures of my progress soon. Thanks
At the front, you could fit a fiberglass or carbon fiber fender plus a decent fork brace.
350 fork sliders fit in place of your drum brake slider, so yo only need one slider to do the conversion and keep your fork legs. You could also fit a better disk to a 350 wheel and get a better caliper than an old heavy cast iron RD caliper.
thanks i never knew i could just do one that saves some time and money, dosent it. i think i have some nice disc breaks laving around the garage but they might be to big seeing that they are for a husqvarna 510 smr. i was thinking about doing a fiberglass front fender which i would use my original as a mold but im worried that i would either be to big seing that i would use the top of the fender. maybe i could make a foam mold because its not to difficult making the foam mold. thanks teazer.
Somebody correct me if I'm wrong, but I was under the impression that the triples on the disc brake bikes are wider than the drum brake bikes. To accomodate the disc.
Basically, you can't mount a disc brake wheel on drum brake forks/triples.
I got a 34mm front fork off a rd400 the chrome tubes are shot but the lowers are all ya need pm me if ya need them
Dont know about the spread but i should have a rd400 triple and a few dt250 triples
The RD disc triples are wider than the drum setup. If you are going to swap the front brake setup then you need to change the triples
VonYinzer said:
Or cut a couple spacers?
There's no spacers on the front wheel... Oh that's what the box of spare parts was for.
But isn't the axle bolt the spacer on the one side and the speedo drive on the other.
Mike: you forgot that you need a bigger hammer
well thats what i was trying to figure out because people have told me that you could swap them. Im not sure if the Rd400 would work tough. im not sure if it is the same triple and forks. could i swap just the forks than get a new tire. like getting a new triple is bad i can do it i was just wondering if i could avoid that. thanks for the info guys
Swapping a triple clamp from RD250 to 400 (if it's necessary) is no hassle at all. Work yes, but not like swapping to say USD GSXR forks - that's a hassle.
2stroker, check out www.2strokeworld.com
They know the RD's inside and out, and can let you know exactly what will interchange and how to do it ;)
If you want to use the disc setup, you will need to change the triples. I had to when I upgraded my RD.
from this
to this
