1sttimer
Over 1,000 Posts
Hey guys,
I recently had my cb175 cylinders (stock bore) honed and new piston rings installed. He installed a 4-piece ring design where the stock design has 3 pieces. The bottom oil ring is just one piece where the new design has an upper and lower ring with an expander in the middle. Well, they apparently didn't do a good job of reinstalling the rings because the bottom one on one cylinder came unseated and has been riding in the interference between the cylinder wall and piston. In other words it's been grinding the whole time. When I took the engine apart, I saw the fresh hone job and then an area where the hone is wiped off from the unseated part of the ring.
I don't have a bore gauge so I dont know how much material has been removed from the score, but you can catch it lightly with your fingernail at the end of the stroke length. I would guess maybe .006" deep? I looked at .01" on my calipers and it doesn't seem that deep from the eye. I called the guy that did the installation and he said he would re-hone it for me for free, but I'm wondering if too much material has already been removed such that now I need a new bore along with a hone?!
If I just hone over it to make it smooth will I start burning oil? All other surfaces are perfect. No pitting at all. This is the only issue.
