pyro139 said:dont lower a 650 at rear unless you ready replace side stand cause it will stand to upright at point can fall over other direction.
Will McD said:no no, i want to raise the back end. but ill just lower the front and see what it looks like for now.
the 650 actualy doesnt have anough lean compared to other bikes so raising it should make it lean just right, raising blocks might work they go between the coil springs and stretch them up, part souce sells them.CanadaDan said:I was wondering if they would catch that... guess not.
The side stand issue goes either way though... raise the bike and the bike is at a greater angle when at rest.
Get a pair of longers shocks for the rear unless you're just looking for a higher angle, lower the front forks through the triples... cheaper.
To figure out which shocks are right you need an expert in the feild... meaining a GOODS parts counter guy.
raising blocks are made for cars so our bikes are so light compared to a car so shouldnt be a problemWill McD said:Hmm, yah thats pretty pricey, specially since the stock ones are still good, so ill look into the raising blocks, though im not sure if they would look very good
we read fined we where just pointing out plus and minus of both raising and lowering.mysta2 said:lol, you guys don't read very good.![]()
