peteGSX
Zuk's Rock!
Hey all, I'm currently preparing to adapt some ZX12 rearsets to my 82 GS450 and I'm trying to ensure I still get sufficient leverage to operate the drum brake properly.
My plan at the moment is to retain the stock splined drum brake actuator that the stock brake lever operates, and to add a linkage to the rearset brake lever. I have a spare brake lever with the pedal end bent and twisted I'll cut down to use, the spline end is good.
I don't know a great way to explain this but I'll try my best and hopefully the pics will help!
I figure as long as the effective radius of the centre of the splines on the brake lever to that end of linkage is the same as from the centre of the rearset brake lever to its end of the linkage it would replicate the force of the stock brake lever with the same action, resulting in still having an effective rear drum brake.
The radius from the centre of that to where the linkage mounts on it is around 30mm.
The radius of the drum brake splined end is about 18mm, so I'd need to make sure the linkage is only about 12mm out from the splines to get a similar effective 30mm radius.
I've included pic's of my measurements below, can anyone confirm my theory here? Does how I've explained it even make sense? I'll mock it up soon but it requires removing the swingarm axle to do so and I haven't had a chance to do that just yet (this is my daily rider).
https://flic.kr/p/2hPWV2F]
Untitled[/url] by https://www.flickr.com/photos/89703844@N08/]starpoint73[/url], on Flickr
https://flic.kr/p/2hPUj2B]
Untitled[/url] by https://www.flickr.com/photos/89703844@N08/]starpoint73[/url], on Flickrhttps://flic.kr/p/2hPUj2B]
