rectifier / regulator help
johnson_steve
OK so how much voltage is supposed to come out of the regulator? Mine is a square box with heat sink fins, 3 yellow wires in from the alternator and red, green, and black wires out. I hooked it up and measured 36v to 40v DC across the red and black or red and green wires. I get 0v between the green and black wires so I assume they are both ground. I know it's supposed to be more the 12v so it can charge the battery but 40v? Does it drop if it is connected to a load? I'm not hooking it up to my new battery until I'm sure it's ok. any advice would be appreciated.
BTW:
Till this gets solved I'm running around town with no charging system and a 4ah battery. :)
