sreddet
oh gnarly
Hello I am building a bobber out of a 81' Honda CM 400. I have stripped everything down to the bare minimum of wiring. Start button, lights switch and kill switch. Unfortunately I have something wrong and the regulator/rectifier is not working correctly. While the bike is running I am receiving 30+ volts to the battery (red wire from regulator/rectifier). This will obviously boil off the battery pretty quick this way.
I have 3 wires coming out of the regulator/rectifier. Black, green and red/white. In my diagram the red white goes to a fuse and then to the battery. The green is ground and the black is for lights??? When the bike is running there is not any power coming out of the black wire. Should there be? Someone also said it might be a ground.
I'd like to see if this regulator/rectifier works before buying one from DCC for $90 Speaking of that, is there a cheaper way?
Any advice would be a great help!
Thank you!
Thank you!
