rejet? Aw man
cb350g
I put a boretech electronic ignition
http://www.bore-tech.com/Vintage%20Motorcycle%20Ignitions.html
on my '73 350G. I had wanted to this but was waiting until the bike needed a tuneup. When it started running rough, it was time. It had very good instructions. After hooking it all up, the final step is to start it up to set the timing using a gun. But when I did this, the idle was very high (2500 rpm). So I set the idle and "balanced" the carbs as shown in the Clymer manual. I found that I could not lower the idle enough and had to even loosen the throttle cable to get it low enough (this took awhile to figure out that I had to do that...) Anyway, I got the idle about right. I can't REALLY tell whether the carbs are balanced (since the instructions basically say to do it by sight and feel) but now, when I rev it up, it backfires. pop, pop, pop
More info:
- I am at 6500 ft altitude and i think the jets are stock.
- The exhaust system is aftermarket and i don't know much about it but it looks like this
So now I'm thinking maybe I need to rejet the carbs. But first, I've never done it and I worry I'm going to get in too deep and two, i don't know whether it's necessary, and third, is it really so hit and miss that you have to put jets in, try it out and then take the carbs completely apart again in order to rejet?
Yeah, those things are tougher than they look!!!! I think I've come to the conclusion to just take my bike to a shop and have them fix the carbs!!!!! I HATE to do this, but sometimes ya just gotta throw in the towel! :-[
Good luck with your build
You shouldn't have to re-jet. If it's been running fine for a while, should still be fine. What do your plugs look like? A good decent tan colour? Popping on decel is caused by an air leak in the exhaust, or a lean mixture. Since you mentioned a high idle, I'd say lean mixture. Have you cleaned your carbs? What's the inside of your tank look like, is it all clean? Are you running an inline filter? Did you use a timing light to set your ignition timing, or just kinda wing it? And lastly, what are your intake and exhaust setup? Aftermarket exhuast? Pod filters? If you've changed either of these, you're likely looking at a re-jet. If you're re-jetting and don't want to bring it to a shop, I'd suggest picking up a Gunson's Colortune. They can be had on ebay for a decent price, and are worth their weight in gold as a tuning tool. This will quickly tell you what needs to be changed.
Before the electronic ignition, it was running hot with some backfiring on deceleration. Immediatel;ty after, high idle. The plugs actually looked pretty good to me. But the fact is that I couldn't read a plug if you paid me really. I'll take pics later maybe and post up.
I am not running any filters that I know of (just bought the bike this spring). Stock air filters. But there IS an aftermarket exhaust (see above). I think I will get the colortune. In putting the electronic ignition in, boretech changed the spark plugs to resistor plugs. Can I still use the colortune asis? I mean, I'm using a special plug when using the colortune... Will it have the right resistance?
The resistance in plugs, caps or wires helps to suppress high frequency noise. High frequency noise can screw with electronics on the bike (especially newer bikes with all their gizmos and dooflunkies), like your electronic ignition if it has some printed circuit boards or IC chips in it. Running a colortune sparkplug for a little bit while tuning shouldn't give you any trouble.
Pics for reference
Right pipe
Left pipe
inside right pipe
Runs hot. See the color?
Plug one. Looks OK yes?
Plug two. A little yellower than in real life. But note the marks. Does that mean too hot?
So any ideas on why it backfires and runs hot?
Wow, I'd never heard of this color tune before, but about $50 to be able to see inside the cylinder while the bike is running! I've got to get one. this will make getting my fuel ratio right so much easier. as a side note it's good to see I'm not the only one with a rusty automotive type exhaust clamp on my bike. :)
Bump.
Nobody can read the plugs? Does anyone recognize the exhaust system brand even? The pipes were on the bike when I bought it...
I have the exact same pipes on my bike, but sorry homie, I have not idea what kinda they are either. I love the sound though.
I'll be tinkering around with mine later and I'll see if I can get some identifiers off them to help you out.
Plugs look ok to me
i was looking at these online for my bike since my stock mufflers were way rusted with huge holes....
http://www.oldbikebarn.com/Motorcycle_Parts/Muffler/Shorty-Reverse-Cone-Megaphone-Muffler#5
but want to make sure they will fit ...anyone know the diameter of the CB450 exhaust?
