Relocating kick stand.
Curbcast
Over 1,000 Posts
Hey Im thinking of relocating my sidestand. Mostly to clean up the ugly factory welds/bracing.
Its for a cb175 & was thinking of even switching it from left to right. Why are most bikes stands on the left?
I need to make alittle room for my rearsets as well, so I was thinking of cheating it up a bit. (more centered on the frame)
Thoughts?
Never thought of that before. Maybe since the right side can be a little cluttered anyway? It might even interfere with the kick-start lever too. Then it just became common practice to have it on the left side?
Just a guess, but most orig mcs had the exhaust low and on the right. You always get off a really (1940s and earlier) old bike on the left side so you dont burn your leg. At least thats what my buddys with really old bikes say.
Fitting on the right could interfere with brake pedal on a stock set up as well as kickstart.
I read somewhere years ago about exhaust as well, even though most bikes didn't have sidestands at the time ( although Vincent had two, one either side so you could use either or remove front wheel)
PJ
Thoughts?
Maybe because the brake lever is on the right? Prior to getting on the MSF teaches to squeeze the brake so the bike doesnt roll and to always have the wheel cocked left to put maximum weight on the kick stand. If your reverse that, all you have to squeeze is the clutch and getting on with the wheel cocked right and squeezing the brake would be awkward.
