You could use some light scotch brite, neverdull, Bar Keepers Friend or just some light polishing compound if you have it. I've found these to work quite well if its just light rust. Obviously there are some pitting issues if the rust is clearly visible. When there is a small break in the chrome surface, moisture gets in these cracks/pits and begins to rust from underneath. If its not too bad the rust will come off and you will barely see the pits. After you get the desired results, I would suggest giving it a light coating of silicone or WD-40 to keep the finish up. Once the chrome pits it needs more attention to keep the rust away.
