Replacement battery
gomotomoto
Can anyone recommend a decent replacement for this one? Under 50 bucks if possible. I'd like to use amazon for convenience.
http://shop.advanceautoparts.com/webapp/wcs/stores/servlet/product_12-volt-power-sports-battery--1-piece-autocraft_2090465-p?vehicleIdFromReq=-1&isAllVehicle=true&vehicleIdSearch=-1&searchTerm=7l-bs&showTitle=
it's funny, I found that battery, but they are out of stock in all stores. Can you reccomend one that's sealed/charged and ready to go?
I just bought one at an Advance Auto yesterday. It was out of stock on Thursday or Friday when I went into the store, but they had it in for me on Monday, so talk to someone about it and make sure they get one in for you.
Why? It is very little effort to fill the battery and recharge it. The electrolyte for an AGM type battery comes in a multi-chamber bottle that automatically puts the precise amount of acid into each cell, then you gently charge it for a few hours. I do it all the time.
The problem with the AGM batteries that come already filled and charged is that they may have been sitting on the shelf for too long. I have seen them with a date code over three years old! That battery would be dead as a doornail and useless. AGM batteries hold their charge sitting on the shelf better than flooded cell batteries, but they need to be checked for state of charge after 3 months, and recharged if down to 75% or less. You CAN tell how long one has been on the shelf. Each one has a date sticker of when it was shipped from the factory. It's a 3/4" round sticker, black background with a white letter and single digit number. The letter represents the month, and the number represents the year.
A=Jan, B=Feb, etc. Exception is that they skip "I" because it's too easy to confuse with "1." The single digit number is the last digit of the year. Example, "1" would be 2011, assuming that the battery has not been sitting there for a decade and it was not shipped in 2001.
If a battery has a date code older than 3 months, check its voltage before buying it. A fully charged AGM battery will read 12.8V or higher. An AGM battery at 75% charge will read 12.6V. I would not buy one that has been sitting long enough to read below 12.6V.
Contrary to what it says on the box, a "ready to use, no-need-to-charge" AGM battery should still get a good refresh charge from a low current battery maintainer before being put into service.
OK, that's a good voltage, (75% or better charge,) so yes, give it a low current refresh charge before you put it in service. A 1 A charge would be better than 2A, but 2A is OK.
