about to tear down my '82 cm450 to fix some oil leaks and routine maintenance on the motor.
while shes apart, is there anything i can do to upgrade the power some? bigger pistons and new cylinders? i know carbs would be everyones first recommendation, but my carbs are new and ill just rejet them.
but is it possible to install larger pistons and the proper size cylinders to run them to change compression some. what pistons would i wanna run if so? what clyinders? are there companies out there who make such things?
im new to these kinds of motors, im a small engine tech for a powersports shop so i understand rebuilding smaller engines, pretty much the same thing though.
thanks in advance for any help.
heres a picture of her from the other day.
