Resistor caps are made to limit EMI (Electro Magnetic Resistance), which is extremely important in digital electronics (such as those found in on-board computers and electronic ignitions).
Large levels of magnetism can create voltage spikes when those fields collapse (this is exactly how your coils work). Likewise, large voltage levels can create magnetism which can be picked up by wires in and around your HT leads (aka plug wires). Because digital electronics generally run at the +5V range, it doesn't take much EMI to create a false signal.
Also, plugs are specifically designed to work with or without resistor caps and you don't want to mix the two up. If you switch to resistor caps, make sure your plugs are NOT resistor types. If you're running 0ohm caps, resistor plugs can be used. 0hm caps and non-resistor plugs should only be used on vintage machines without any modern electronics.
Short version: Resistor caps keep your electronics working properly.
