Rick's Hot Shot Stator
  • Thread starter Thread starter arudeseal
  • Start date Start date
A
arudeseal
Guest
Hey guys,
Is it possible to buy the Rick's hot shot stator without buying the regulator too? Everywhere I have looked sells them as a package. Additionally, are there any high output alternatives besides Rick's?
Thanks in advance,
Andrew
Well balls. Guess I'll be dropping the 200+ bones for the system. I have the radio shack replacement for the rectifier, but I'm still only getting about 13.6 to the battery on high revs.
Are there any alternatives for high output stators that work with the existing wiring harness? I've searched but yet to find a solution. I know re-wrapping my current one is an option, but I would hate to go through all that trouble with minimal results.
You can always do the old yellow wire to white wire bridge trick. More difficult to explain than do.
Yeah, I have done it already actually. Problem is, I like to ride with my light on during the day anyway. Drivers here in Atlanta are ridiculous.
I ride with lights on all the time and don't have problem (unless bulb fails)
Nothing wrong with 35+ yr old charging systems as long as you didn't chop into stuff and wire things wrong
It's most def possible that the PO did something funky, or that loose wire ends are causing issues charge issues. The wires inside the headlight are such a rats nest that I haven't spend the time to check everything yet. That would def be step one, but I wouldn't mind being able to add some extra lighting up front as well as a brighter bulb, just for safety sake. The less chance I give someone to pull out in front of me, the better, especially in a city that is notorious for hit and run drivers.
Thanks,
Andrew
Switch everything to LED and fit a H4 headlight.
Brendon seems to have no issues with 60/55 But personally I would use either a 35/35W or 45/45w scooter H4 bulb
Either is brighter than stock incandescent.
