dp9
Coast to Coast
Anyone ever considered running alcohol instead of gasoline? I was just throwing the idea around with a couple friends of mine, so I figured I'd throw it out here and see what you guys think too.
From my discussion with my friends we've determined that it would be expensive (to buy the fuel) and limit your mileage btwn fill-up, which would prob have to be at your house. So its not for a daily rider bike. On the up side, theres a lot more power to be had, which = more fun.
As far as feasibility goes, the carbs would have to be converted for use with alcohol (by a shop), you would need MUCH larger jets, and a lot more compression (12:1 at a minimum, 14-16:1 would be preferable). The motor would run REALLY cool with alcohol, so you might need hotter spark plugs. Also, you'd have to change your oil more often (but who doesnt like doing that?).
So as per this convo, my friends and I determined that if there is enough piston to valve clearance that we can can mill the head and/or cylinders to bump the compression to a decent number, this would be a really feasible conversion.
so what do you guys think?
