Running without a battery?
Before swapping out the battery for a cap, you need to do a simple test.
1.) Measure the voltage across the terminals on your battery and write it down.
2.) Start the bike and let it idle. Now measure the voltage again.
If your voltage reading from step two isn't higher than your voltage reading from step 1, it's unlikely that a cap will work.
This is very good advice!
hmm, i'll have to get a cheapo battery and do this test. wiring hasnt started yet so I've got time to plan it out
thanks for the heads up!
