Seat hoop...necessary?
pawn
Over 1,000 Posts
So I have a cb450, and it has that underseat hoop. Since I've been trying to work my own seat up, i've been questioning the necessity of the seat hoop. Is it completely structural? I mean I can't really imagine it does all that much. So is it ok to chop it off?
I'm no expert, but I see a lot of people welding a crossbar level with the frame, or welding a half circle shaped piece at the end of the from to connect the two sides.
yeah I see that as well, but since I don't have a welder, it's not really an option for me. But the seat look I like is simple and flat.
I believe that is there to provide stiffness between the two sides of the frame near the rear shock attachments. It is probably best to keep something there. I've seen a couple people cut it off, but they always replace it with something else. If you can't work your seat around it, I think you will have to find someone to do a little welding for you.
i can see your point. I just didn't really believe it provided all that much stiffness other than being a piece that can hold weight from the seat.
I think there's a lot of stress right there because of the shocks being there, but really, you could hacksaw a piece of tubing to fit and probably pay some muffler shop ten bucks to weld it in. Better safe than sorry.
yeah I guess I'm gonna have to do that. I like the look of a flat seat better than the cafe hump style. Not to mention I'm having a hell of a time making the cafe hump with fiberglass, and to match the contours of the frame without gap.
I cut the frame hump off of my CB200 because I was going to make a flat seat, but then decided to use the original seat pan to build a cafe seat. I only had the bike on the road a short time before the motor took a crap on me, but I didnt notice any issues with not having that frame support. Of course my bike is REALLY light and there is not a ton of stress on the rear end! Hope that helps!
That little bit of steel is all that keeps your frame from distorting at the shock mounts. Not only is it adding linear rigidity but also torsional. It may no look like much but you need something there.....
Ok, so I have a friend to help me weld a piece of tube in place so I can get rid of the hoop. Another person mentioned to me that the suspension travel might cause the tire to hit the seat if I do in fact make a completely flat seat. Has anyone made a flat seat and not had this problem?
I cut out my rear seat bracket/brace off and welded a bar right across the frame essentially "connecting" the shock mounts.
so you have no problem with the tire hitting that bracket now since it's about 1.5" lower than stock? I'm a little worried that my ass might have tread left on it if I hit a pothole.
That brace is to support the extra weight when having 2 people on a bike.
I you are gonna put a single caferacer seat on it and not carry any one on it.. Id just chop it.
We chop those loops off for all the cb360s we've built....
Unless you are going to race it on a track at 120mph and corner at a 45degree angle, you are not gonna feel any difference in the frame stiffness...
but have you built them with a totally flat seat, or do you always make that "cafe hump"? I jusst really need to find out if the tire will in fact hit a flat seat or if I can get away with it.
I've done both... used a cowl from a chopped tank bolted on to the stock seat pan, (kept the rear hoop support), and used a flat fiberglass seat and built a bracket...
In both cases, the bikes have never bottomed out...
ok that's good to hear then. I can't wait to get started, unfortunately I have to, but in the meantime I'll be figuring out a tailight-lisence plate mount, and trying to find a good piston for my front brake caliper...so I will be busy.
That plate that is welded in there sits at about 5 inches from the tire. i would have to go over one helluva bump to bottom out on that
