Should we see oil?
Texasstar
Can't is a four letter dirty word
We have turned our new motor over with the starter for about 30 seconds and have the tappet valve covers off. Should we see oil?
Did you use cam assembly lube on the cam? It may take a while to push out the heavier lube from the holes in the cam lobe.
30 seconds isn't very long for that tiny pump to move much oil.
I turned mine over for a while, then pulled the stator side cover to check if there was oil in the galley which goes to the crank and up the studs to the head. Sure enough there it was.
Upon replacing the stator side cover. My final confirmation was when the cam holder gaskets started leaking.
Hopefully yours is buttoned up tight. ;)
When I switched my clutch sidecover to one I had modified for an external oil line, it was much easier to see how slowly it flowed.
CB200 has trochoidal pump, you won't see oil splashing about as cam probably isn't turning fast enough
Damn, can't remember whats in there ;D
I don't think I've been inside CB200 since late 70's (probably 78~79) I know last time I was in a 175 was 1977 ??? (blew out left big end chasing a Suzuki 500 twin @80+ mph ::) )
Oh well, the point is still valid.
You can loosen one of the outer rear cam box acorn nuts to check oil is getting to top end, kicking it over will get oil up there
