slight electrical prob, help pinpoint (pics)
funkja
Active Member
had an interesting issue the other night, on my way home i lost all side markers and horn, no turn signals. shut the bike off, turned back on no lights but now i have horn. beep beep. then horn goes away. loose wire imma thinking. got movin again, @ stoplight and wham hey hey i got side markers up front + horn + blinkers. what about the rear? no side markers and when i flip turn signal front signal works fine but rear 2 flash like hazards (both blink, doesnt matter if signal right or signal left turn).
electrical is stock.
any experienced electricians track it down with that? imma electrical newb and would like some direction b4 i go digging.
basically headlight/brakelight/front markers+front signals work fine, rear markers off constantly and flash like hazards when i use turn signal.
Re: slight electrical prob, help pinpoint
Sounds like you are loosing your ground. Check for rust/corrosion on where the harness grounds on the bike. I had similar gremlins on stock harness and I had to clean up a bunch of the connectors. Even ones that looked ok would not pass electricity well. Filed, saned etc. and fixed the grounds and everything now works right, even lights that didn't work when I bought the bike. A cheap test light can go a long way to finding out the week or dead connections.
ok so i went through and check the wiring, all grounds look good and corrosion free (cleaned em up with those wire toothbrush thingers)
however, i did find one wire that concerned me.
looking at the schematic connected to the turn signal relay is a green/white and a green wire. on my bike its green/white and white.
also behind it on the rectifer bolt theres a green wire unattached to anything that was burnt/corroded to all hell. .
so thinking the green wire was jacked and USED to be attached to this other green wire in the loom, i hooked em up hoping this solves my issue. no dice. what's the worst case scenario of connecting this wire? anyone have any ideas where it would go to? its attached to the bolt holding the rectifier(i think its the rectifier) and the wire its plugged into wasnt attached to anything. im unaware if the PO did any wiring himself.
also whats all this black rubbery stuff over everything it's not like oil, its solid like rubber and its coming off of something above like the turn relay or those boxes (CDI'S?) ?
pictures are worth a thousand words. and dang my cell takes GREAT pics @ half resolution.
ok turn signal problem solved. my ground tab INSIDE the back stock bracket had broken off, not seeing a tab, i didnt think twice. so that issue resolved.
still wondering what this rogue wire is? and my melted CDI's, they still work but for how long? and whats good to replace with?
