Smelting cable ends
Basement rat
Over 1,000 Posts
A week and a half ago my throttle cable broke on my sled. I thought it was the throttle cable however it was a weird intermediate cable/ system?... I couldn't find the part, ANYWHERE, not online, not at my parts store, the local (only) bicycle shop did'nt have any connections like this or anywhere. So I made one. Here's how it goes. (my camera is on the fritz and the bike takes priority over a new camera)
The broken cable and looking through my scrap shelf I found an old choke cable from my 750, the clip broke but the cable was great:
File lead knob to fit the case:
Next my inital plan was to take a mold of the old what I thought was lead piece, heat it up, remove the old broken wire and insert the new one. Its not lead... I pulled the piece out and used what I had as a mold for lead. Next problem was the wire just slipped out. I bend an electrical connector from my assortment to crimp on the wire and fit inside the lead piece:
Next and last step was file to fit/ match the old one and install.
Done!
Questions?
unless i missed something in the fabrication process, there is a good chance that won't work. When those types of ends are made the lead is essentialy brazed to the cable making it almost a single piece. I'm pretty sure (not 100%) that the wire crimp end you're using won't have a strong enough "bond" with the cable to survive the repeated tension of the throttleing.
I saw some info somewhere that there is a kit out there for actually soldering spare ends to cables after a break, but that they are for "emergency use only" and not intended as a full time use item becaue they would break again.
I hope it works for you and sorry if not.
tim
Main problem I've found is the original cables are stainless steel wire ( at least newer ones, last 10 ys or so?)
The ends are probably pot metal (basic zinc diecast?)
PJ
