Cale Young
My question is about heads. I pulled the engine on my CL350 to get the piston unstuck. Tore down to the pistons to find the right hand cylinder rusted in place. I used a method I had read about here and on hondatwins to un-stick the piston which took about a 1/4 cup fuel 1/4 cup A.T.F. and an old sock for the wick and lit in on fire. Put it out and let it cool and it pressed right out. Now I am trying to clean the heads up and I am to the point where I need to get into the intake and exhaust openings but can not find anything to get inside to finish cleaning all the corrosion out. Basically trying to get the guides cleaned up enough to replace without tearing up the head. We have a soda blaster here at the shop. Will this be ok to finish out the process or will it fowl everything up? As always thanks for the help.
