some stuff I have
Mortikan
Coast to Coast
I have
1 two into one exhust the outer diameter of the pipe is 9/16 I believe. I can check, the chrome is very good except in the crack where they come together.
1 very nice set tach and speedo from a 1973 cb450t blue back ground mint glass is perfect the black outer casing has a few chips from the paint looks like it can be touched up. the back is good clean condition there is 15xxx miles reading on the speedo. they both work.
1 set of very nice levers pearl painted bought for my 73tx but they are for the later 76 -up xs might fit other bikes
1 set of triple trees for xs 650 from 75 in very good shape the tree has been bead blasted the top end is currently being cleaned up for primer ALso have set of races and ball bearings if your going for nos.
1 mikuni carb from early xs (probably 72)38mm but everything is there and no rust on exterior. dirty rag condition
1 choke pull handle and shaft used on xs650 34mm mikuni from 80-84 in good useable shape.
1 kick starter off 1980 xs650 thicker and streighter shaft than the older versions same splines. alloy very clean I just rebuilt new bearing /rubber is in very good condition
1 right side brake caliper from xs850 in useable condition (needs to be rebuilt and new pads but it works/holds pressure currently)
I will also be posting many more things up for trade I have quite a few sets of rear sets I was intending on working out but no longer want to use
I can post pics of stuff if needed.
Re: some stuff I have & what I am looking for
Mortikan - you can order the spokes you need from Mikesxs I think for pretty cheap. Brake shoes for the XS1 are harder to come by, but I think 650central.com has them.
I've never seen Progressive springs for 34mm forks. Have you considered going to a 35mm front end? Or are you planning on using stock XS1 forks? I had my 35mm forks modified to mate with the XS1 drum brake. I had a tab welded to the forks just like on the XS1 forks.
HEY TIN TIN, Thanks for the info I know about mikes and the spokes buchanans also has them. 650 central has the brake pads there $45 I just figured I would see if I could trade for some stuff. to get what I need.
I am currently running a 34mm setup stock for my 73tx with dual disk but I like the look of the drum. I know the disk stops better but I don't really ride much. I might get to ride a night during the week here and there and on the weekend when I am not busy with life. I have never been to aggressive in my riding so for now looks wins over function.
I traded someone for rim (thats rusted to hell) with a descent a drum assembly from an xs2. I am working on an getting old rim. I just got my perch from a suzuki gt380 and I found the brake handle on gdlcycles for $4.
Cheers
Kyle
