spark advancer cam lube???
m511y
Less is more
I have 73 CB350 and I'm changing the points. I noticed that the timing advancer cam is totally dry. This is the cam that opens the points. Do I apply a little oil to this cam or will it interfere with the timing?
Also, I noticed that there is a little brush between the points and it is a little worn out. Does this need to be replaced or is it fine to let it be. Does it just clean the cam or does it effect the timing in any way.
That little brush (probably a felt pad?) is for lubricating the cam. A few drops of 3 in1 oil on the felt and make sure it's making contact with the cam and you should be good to go. If the pad isn't making contact. You can pull it in towards the cam just enough so it touches.
