spark, then no spark
adwriter73
My 350 seems to be losing spark in the right cylinder. It fluctuates. You tell when the cylinder fires up and then cuts out then fires up. I assume it's a spark issue only because it's getting fuel, the carbs are newly cleaned and jetted and I pulled the plug out to check it three times. First time, I got a spark. Second and third test...no spark.
Try unscrewing the sparkplug cap/lead from the plug wire and holding it about 1/4" from the engine, then try to start it - if you have a good healthy fat spark there, then you're getting power to the plug. You can also check this by pulling the sparkplug entirely from the head and holding it (BY THE PLUG CAP) 1/4" away from the engine fins.
Is possible that you just need to adjust your carburetor yet, and that plug is just getting fouled enough that it can't spark.
