Speedo/Tach Cables....Lube Them?
Flugtechnik
My bike is not transportation, it is a respite
I just got some new speedo and tach cables. Are you supposed to lube them? With regular cable lube? Are you supposed to lube them regularly? Every 3k miles? My shop manual never even mentions the gauges exist.
The speedo cable is an aftermarket motion pro.....and the tach cable is NOS.
Thanks.
ya, i'd say lube them, unless motion pro says not too. cable lube is good. you might try a liquid graphite also. NAPA has a product called "Lock-ease" that is pretty cool. it is like WD-40 with graphite. works great for locks since it displaces water, and the graphite lubes. no matter what you use, i would say lubing them is better than not.
later,
ryan
FYI, I got this response back from Motion Pro. Make of it what you will.
Hello Mike,
Thank you for your inquiry.
We recommend you use Motion Pro Cable Lube P/N 15-0002 for all cables.
If you have any questions, please do not hesitate to contact me.
Regards,
Larry Snyder
Technical Services
Motion Pro Inc.
P: 650-594-9600 ext. 111
F: 650-594-9610
E: larry@motionpro.com
