spring, clutch lever
mickey_7106
can someone be kind enough to measure theirs so that i can just order a generic one?
heres whats compatible
PRODUCT OBSOLETE
This Honda 22815-300-000 SPRING, CLUTCH LEVER is used on these models and components:
1976 CB200T A RIGHT CRANKCASE COVER
1976 CB400F A RIGHT CRANKCASE COVER + CLUTCH LEVER
1976 CB750F A CLUTCH COVER
1976 CB750K A CLUTCH COVER
1976 GL1000 A KICK STARTER + CLUTCH COVER + REAR CASE
1976 GL1000LTD A KICK STARTER + CLUTCH COVER + REAR CASE
1977 CB400F A RIGHT CRANKCASE COVER + CLUTCH LEVER
1977 CB750F A CLUTCH COVER
1977 CB750K A CLUTCH COVER
1977 GL1000 A KICK STARTER + CLUTCH COVER + REAR CASE
1978 CB750F A CLUTCH COVER
1978 CB750K A CLUTCH COVER
1978 GL1000 A CLUTCH COVER
1979 GL1000 A CLUTCH COVER
Models with no year CB200 A RIGHT CRANKCASE COVER + CLUTCH
Models with no year CB200T A RIGHT CRANKCASE COVER
Models with no year CB400F A RIGHT CRANKCASE COVER + CLUTCH LEVER
Models with no year CB750F A CLUTCH COVER
Models with no year CB750K A CLUTCH COVER
Models with no year CB750K1 A CLUTCH COVER
Models with no year CB750K2 A CLUTCH COVER
Models with no year CB750K3 A CLUTCH COVER
Models with no year CB750K4 A CLUTCH COVER
Models with no year CB750K5 A CLUTCH COVER
Models with no year CL200 A RIGHT CRANKCASE COVER + CLUTCH
Models with no year GL1000 A KICK STARTER + CLUTCH COVER + REAR CASE
You can use any pull spring that you can squeeze in there and fits the mounting holes. What is important is the "stretch strength" ( forgot the scientific name for it). You can check other parameters on this website http://www.sodemann-sprezyny.pl/sklep-internetowy/sprezyny-naci%C4%85gowa/traek_ab_rustfri
